Mike T
- May 3, 2013
Needed a neutral hub for a project so I modified a stock na balancer. Used a mini lathe, drill press and a die grinder.
SignUp Now!I neutral balanced a stock damper back in the day. It was a bunch of work and I ended up damaging the trigger ring getting it off. I never finished the project because I didn't have a good fixture to properly locate the replacement trigger ring. The TA unit is the best bet I have used them and they are really nice but don't break the bank.I believe the part # is TA V2026
For the TA performance unit.
It has a removable counterweight that allows it to be used in internal or external applications.
The TA 2026 is for v8s so be sure that you're searching with the "V" part number for our v6
Got it, I wont mess with the stock one then. My buddy has a ATI Super Damper I might be able to use, if not I was looking at TA's neutral balancer for $350 the TA_V2026, ati new wants $515 for 917456. Thank you Neal!I neutral balanced a stock damper back in the day. It was a bunch of work and I ended up damaging the trigger ring getting it off. I never finished the project because I didn't have a good fixture to properly locate the replacement trigger ring. The TA unit is the best bet I have used them and they are really nice but don't break the bank.
Neal
