Made it to Bithlo Tonight,1st Run with the Nitto's
The 89 TTA came with a larger one. Dont know if its stronger.
But..
I def would get a GM piece as it will be stronger. The Dorman stuff is chinese..
On subject.. on my TTA I used one I got from Summit it was a billet one.
Summit Racing SUM-G1465 - Summit Racing® Vacuum Check Valves - Overview - SummitRacing.com
I ran -6 hose to it using the AN style fitting. I blew my hose of my stocker at 28 PSI once and it was scary.. I went to this style never had anymore probs.
Thanks Pronto.....
I will get one tomorrow,go wide open throttle and then see what happens....
I'll post my results when i do...
Thanks again
Check Valve
But..
They have it in stock,i will order one now and in the mean time i will try the one pronto suggested,its only $5.99 i can't go wrong...
Thanks again for your time and thoughts
Remember the Summit piece doesnt have a barb but -6 AN thread. So you need -6 hose and a -6 hose end female that will thread over that check valve.
i got the summit check valve,now where do i get what you told me that i need?
-6 hose end female?
thanks sir
