SignUp Now!Originally posted by bruce
Yep,
you can have MAF drop out,
and Timing Drop Out.
At over 6,375 the timing starts to do about the same thing as the MAF, ie erratic, (low) numbers.
Originally posted by TurboDave
6375 doesn't surprise me at all. It seems to be the limiting factor on the stock PCM's, in several places.
The most glaring of which is the rev limiter. Since FFh is the largest acceptable byte size in our PCM's that's the highest rpm you'll be able to supply fuel to. Since FFh in the rev limiter = 6375rpm, then there's probably other limitations based on that rpm elsewhere.
Originally posted by Ted A.
Steve Wood?
Originally posted by John at J&S
Good work, Bruce. Don't you just love the smell of solder in the morning?
Originally posted by gnjones231
This is not right. Bruce did not correlate anything again. In the words of Gomer Pyle "shame, shame, shame'. I've been through this before in this thread.
http://www.turbobuick.com/forums/showthread.php?threadid=46755&referrerid=746
The ECM will control timing to at least 8000 rpm. No drop-outs of timing. No drop-outs of maf either. As Far as fuel drop-outs, So far you have two choices....The stock chip will cut fuel cleanly above the limit in the chip. A Thrasher chip will do a drop out at 6000 rpm like a stutter. Maf drop-out has nothing to do with rpm above 6375 rpm.
Dave
Well, excuse me for reading what you wrote. Maybe you should rephrase this quote.
