Feb 14, 2018 #1 1 1972chevy Active Member Joined Feb 12, 2018 Messages 164 my scanmaster G is reading 5 on the maf when the car is off. i was thinking it should be 0. is this a problem?
Feb 15, 2018 #2 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,543 Turn the key on but don't crank the engine. Put the Scanmaster on MAF and slowly push the gas pedal to the floor. If the reading increases, you have a problem. That means the ECM is making up numbers so the car will run.
Feb 15, 2018 #3 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,672 the MAF will never read 0, it either reads the sensor (with a min reading set in the chip), or it reads the backup mode calculation based primarily on throttle position. Bob
Feb 15, 2018 #4 1 1972chevy Active Member Joined Feb 12, 2018 Messages 164 I did what you told me, it just stays on 5.
Feb 15, 2018 #5 1 1972chevy Active Member Joined Feb 12, 2018 Messages 164 stock maf is off and now i'm going to set up the translator. Is the Delhi mass airflow sensor AF10043 a 85mm or a 3.5 ls1 maf?
Feb 15, 2018 #6 G Gary Durden Active Member Joined Nov 17, 2002 Messages 251 I noticed you had another question about your Scanmaster G in the transmission section. Why not write down your questions and contact Bob Bailey.
Feb 15, 2018 #7 E Eric Stage I TurboTweak Guy Joined May 25, 2001 Messages 2,676 1972chevy said: stock maf is off and now i'm going to set up the translator. Is the Delhi mass airflow sensor AF10043 a 85mm or a 3.5 ls1 maf? Click to expand... That's the 85mm MAF
Feb 15, 2018 #8 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,543 1972chevy said: I did what you told me, it just stays on 5. Click to expand... That means the ECM is receiving data from the MAF. Since the number is static, the ECM isn't having to make up stuff.
