Majorly bummed out. Look at pics
you ran more than one that was broken in the register, Take it back, they will see they caused the problem, have them dowel the cap better than new, they should do this FREE !
Reference pontiac 400/455 :biggrin:
If you run it and it breaks I can hear the machine shop now, "Man... you should of said something. We would have dowel pinned it for free if we'd known.":rolleyes:
Have it fixed...:)
Cast iron welding
I hate to Highjack this thread, but I was asked about my comments on welding cast iron:
Successfully welding cast iron is certainly possible. But as you have heard it is full of problems and is best left to the expert welders. I've run into plenty of "backyard" guys who claim they can stick weld cast iron with nickel rod.
OK, they can probably make the metal stick together and look OK. If this is in a low stress area of the casting, it might live a full and productive life!! But put this area under extreme stress.......say a main bearing web in a block, and the problems will show themselves.....and not in a good way!
Inspect it with magnaflux or better yet X-ray afterwards and report back!!! Because the localized heat of the weld pool tries to expand the metal around the area, it puts a radial pressure on the casting. The cooler metal around the weld pool doesn't move and if it does, it will produce cracks. The "HAZ" Heat Affected Zone around the weld pool hardens the metal and again promotes cracks.
Preheating is always required for effective cast iron welding.... and when I say preheating, I'm talking 1500 degrees F. Higher than most welding shops can effectively produce for the entire casting. It is generally accepted that a long cooling process and stress relief process needs to follow cast iron welding
Don't misunderstand me, I believe Cast iron can be successfully welded and repaired. But to do it right, It takes an expert with alot of very good equipment and expertise.
Here is a good source to read if you you want more about about the effective repair of cast iron:
Full Torque
We have some pretty darn good welders who frequent this board, Please weight in and let me know if I'm off base with my opinions.
To be constructive to the problem at hand: I think this block can be saved by machining the block and cap on this one main cap for dowel pins. It can probably be done without disturbing the main bore and should not require any other block work. I agree with Rich's comments about the problem: You wouldn't have asked if you didn't know this might be a bigger problem. Fix it now and run the daylights out of the engine without worrying about it!!
Dave
I have a block almost just like that. Pete (ANS) told me he purposely knocked those corner chunks off the register (all of them) because more often than not the peices would fall off on their own and end up in the oil pan. This was way back maybe 8-9 years ago.....
Never had any issues with the block in that area. I did crack one of the bores and had to have it sleeved, but no issues with the mains. It's in the car now but I'll have it out in a few days for a motor swap. I'll try to take some pics of it for comparison.
what would be the proper way these blocks have had dowels installed?
anybody have pics or have it done ever?
talked to pro gram engineering about my problem since they manufactured the caps.
he said to dowle the main cap bolt hole with a steel this round insert. should be better than new.
i am going to get that done and get this nightmare installed.
Good move.
Dave......welding cast iron only take SIMPLE welding equipment. A local cast iron welding repair shop showed me how to do it. I have him weld repair cylinder heads that I have gone a little too far with.:eek:
1) Grind away the area a bit to expose clean iron
2) Pre-heat to RED HOT with oxy-propane torches placed at each end of an oven that he makes out of fire bricks to accomodate the size of the part.
3) Remove a brick or two to make an access hole to weld into.
4) Use an oxy acetylene torch with a solid 1/2" cast iron welding rod.
5) Keep the pre-heat torches running to keep the part red hot
6) Weld the area with the torch and cast iron rod
7) Replace the fire bricks and let cool for a few hours
8) Quickly remove part from the make shift oven and wrap with thermal blanket, lay on floor (carefully) and immediatly bury the part with a BIG pile of sand.
9) After 24 hours of slow cooling, shot pean the entire part in a steel shot blaster.
10) Re-machine all areas of the part. Done.
Simple tools and equipment, but very time consuming. He has weld repaired some terrible damage and it comes out perfect. You can't even tell it'e been welded. BUT.......that is the ONLY thing he welds. I may have missed a step or two, also. It's been 10+ years since he showed me how to do it.
I have welded cast iron with a TIG and stainless rod. Stainless and cast iron have similar heating and cooling characteristics. Similar is key word here. I have also used silicon bronze to repair a gouge in a cylinder head deck on an FE Ford for a local machine shop. Worked great.
The only other feasible option would be to weld a bead on the edge of the steel cap and re-machine the register in the block to accomodate the wider cap. (after machining the welded cap edge)
dropped off the block at another machine shop.
going to check the area for any cracks.
dowel both center main caps and recheck the main bores and line hone if out of spec.
will post picks when i get it back. wish me luck
