I don't have any pictures on this, so people will have to picture this in their mind.
Has anyone run into the problem of their tilt steering wheel adjusting itself into their lap as you're turning hard on the steering wheel? This would be much more of a problem where steering boxes have been converted to manual steering boxes for drag racing. The manual boxes require much more effort to turn the steering wheel and since most people pull down on the steering wheel during turning, a serious safety issue arises.
Some years ago, on a certain pass down the track that got a little out of shape and required me to do some superhuman steering to straighten her out, the steering wheel tilt went into my lap right in the middle of my struggle to straighten the car out. I had earlier switched to a manual steering box inorder to remove the hydroboost system that my car came with.
The fix is to limit the travel that the tilt steering wheel has so that you don't have the tilt adjust itself on you during a critical time. This fix is also very simple. It requires you to disassemble the tilt steering mechanism to the point of being able to drop a length of steel rod into the middle of the spring that does the job of returning the steering wheel to the most upright position when you pull on the tilt adjuster lever. The steel rod needs to be of the correct length so that the steering wheel will drop down to the driver's preferred position, but will prevent the steering wheel from adjusting any further downward.
