Manual brake setup
PA racing Aluminum plate with mopar master cylinder. I need to double check the bore but was used with stock brake size. SSBC stock location mounted adjustable prop valve. B&M line lock (never used) mounted on power steering bracket. Russell braided brake lines to the valve and fittings. Brake pedal included with modified rod pin. All in new shape.
$375 shipped.
Interested in the line lock if u want to separate
