I bought a new (reman) manual S-10 brake master cylinder, bench bled it, and put it on the car with a custom length pushrod. Just a minute or two as I started to bleed the brakes, I heard a "clink" as the pedal was coming back up and looked under the dash to see that the pushrod had lost it's seat because the master cylinder piston did not return to full stop. It even stayed this way until I pulled it off of the car and put it in a bench vise to take a picture. Now, I can't for the life of me think of anything I did incorrectly, although I'm not ruling out operator error. However, just an FYI, that IF there are bad reman units out there floating around, you other fellas running this same set-up should be aware of this potential problem. FYI, I bought this unit (Part #10-1905) from Advance Auto Parts and the box had a sticker indicating that it originated from a company called OEM (Original Equipment [Re]Manufactured):
