Long story short. Have a GN with no history but it's well modded. Upon start up, roughly 10 seconds after it's running it sounds like marbles spinning around the torque converter for about 1 second. Only does it cold or after sitting a long time. Like overnight. I have no reason to believe it's the engine as it carries good oil pressure hit and cold. Has 80psi oil pressure when the noise happens. Plan to look at the flex plate but what are some other things to check?
The converter is unknown aside from it's a lockup and it's purple. When it locks in OD it provides whiplash even at light throttle.
