John Wilde said:A rule of thumb for estimating is 18% drive train loss with an auto.
Kenny had a Liberty 5 Speed with Clutch that I am sure there is much less maybe less than half. I would say that when Kenny was going 6.8s at around 2300lbs he was making a little more than 1400 to the wheels!
When kenny was campaining the red car he used an air shifted owens transmission. The race boost setting was 30# and he made 1100 rwhp with this setup. I am absolutely positive he knew exactly which gears and transmission ratios to use to get that number. Rear gear was 500. A lot of guys ask duttweiler which rear gear/tire size/ and trans ratio because he has this info down to a science. I was told 4.57 based on a 34" tall tire and some trans specs I was throwing around at the time. i have no doubt it'll work like kenny says it will.
