SignUp Now!John Wilde said:Here are the Chapman Heads that I had, these are the same units Kenny went 6.8s with!
Please keep in mind I was going to use a cam bigger than .700 inch!!!![]()
Intake Port Volume: 247cc
Exaust Port Volume
Chamber Volume 40.5cc
Valve sizes and Lengths
Intake Valve 2.100 x 5.540
Exhaust Valve 1.625 x 5.560
Flow Figures @28"
Intake Exhaust
.100 68 53
.200 145 113
.300 221 174
.400 281 213
.500 321 229
.600 336 241
.700 341 247
Extra Info NOTE: This program will only work on select castings. Please call for more information.
DonWG said:So far up just under 1800HP.
BMEP 680.
Max cylinder pressure around 3500.
130 octane gas.
85% eff. intercooler.
Knock numbers on the hairy edge.
Torque curve flat from 6400 to 8000 rpm. Looks impressive.
Is it practical to run twin 76s at 45 psi? Would they surge before getting in the power band?
Looks like a single T-106 at 45 psi would be a piece of cake.
ijames said:Billy Anderson once posted here that the best flowing Stage II heads he had ever seen topped out at about 360 cfm, and he put those heads on his car.
Nitro would require a totally different engine setup. Nitro's octane number is horrible and the fuel is harsh. I'm going to switch the combo to alcohol, optimize the CR and see what we get.Big Stu said:I really wanted to run a lencodrive with twin custom 78's but money is holding me back. If i had unlimited resources, that is what I would do. I like the idea of a 106 at about 45psi but that would be a bitch to spool using anything other than a stick/ or nitrous/automatic combo. The having to run the equivalent of 130 octane is where the nitro would come in handy I think. I wonder if I would have to run two magnetos?![]()
DonWG said:Nitro would require a totally different engine setup. Nitro's octane number is horrible and the fuel is harsh. I'm going to switch the combo to alcohol, optimize the CR and see what we get.
Have you considered a Bruno? I hear some fantastic things about them. Oh wait. Is the Lencodrive the torque converter drive setup?
DonWG said:Opened the primaries on the exhaust 1/8".
Slowed the spool up slightly, shifting the torque curve to the right just a bit with a new peak HP of 1810@7700.
Knock numbers still an absolute dream. Even with the low knock numbers, I suspect the BMEP and peak cyl press numbers will be over the capacity of the vast majority of rods available. Maybe a custom built pro mod design with a thicker I beam? Steel or titanium?
OK! Where can I get a set of heads like those? They're on my must have list.
One thought. If your running alcohol, you can forget about any internal water passages so a head flogged from billet is very do-able, bypassing the casting setup and production process. Anyone interested? Can anyone supply me with Stage II head blueprints? That would be the best starting point. Does anyone have proven intake and exhaust port dimensional draw ups that they want to sell?
DonWG said:Turbine housing size looks to be very critical with the T-106. I choked it down slightly and lost a pinch of peak HP but gained a bunch of meat under the overall torque curve. One drawback being that the knock numbers are starting to creep up.
Max hp 1828.
Max trq 1317 and getting broader and is flat.
John Wilde said:Don,
Are you still running the 4.11 Gears?
If so I think the car would do much better with something in the 3.4 to 3.7 range.
Big Stu said:Yes, those were the Bennett ported heads. I have heard of over 368cfm intake but I couldn't tell you for sure if that's true or not.![]()
Dusty Bradford said:When were these done? I know several guys at Bennett if your talking about the shop here in Alabama. Were these numbers from Bennett or from someone else flowing them?
Also. If a rod can be made to take the abuse I would think an alcohol motor with billet head without water ports would be the best way to go. You see these in the diesel tractor arena and they take a serious beating.
