SignUp Now!Originally posted by GotGas8668
i relocated the alky kit its behind the passenger side head light i bought a radiator coolant reservoir kit and used the bracket from it and bolted it in there ran some more line and made some hoses to fill it works great cost me about 20 bucks to move
yes exactly i relocated it to in front of the battery i had to mount the tank from under the car you cant see it at all just the hose going to the up pipe and yes it is really hard to fill but i fixed that problem i bought some clear hosing from weslake and drilled out the lid of the tank then i put a fitting in the lid and attached the hose to it and made the hose long enough that i could get a funnel to it i pull the plug on the hose and then fill the tank up works great and fixed my problem for not having an area to put the thing
i just went to auto zone and bought one of those radiator over flow reservoirs and i used the holding bracket that came with it its the right width for SMC's ractangular container but its a little to deep so i put some foam around the container do it wouldnt rub and then tightened it in with a few zip ties it was a really good installataion and upgrade
exactly you cant see anything except this braided hose going to the up pipe which some idiots have accused me of running nitrous through especially when i turn on my CO2 fogger for the intercooler
hey keith its nathan the one who called a million times and finally got that new intercooler ordered
