Mer & Th400
KWIKR 1
has anybody with a MER done the TH400 swap ? I've been told you have to install/mod the column linkage to the TH400 .or you will end up with a rich condition in park while at idle . what has to be done in order to make linkage fit the TH400 ? thanks .
I will set you up with a dfi, you no longer need to worry about that! If you don;t go faster you get your money back!
I have done the swap but, I don't have a column shifter. I simply disengaged the linkage bar from the transmission and to make adjustments I engage the neutral safety switch by moving the column. I havn't notice any problems with running rich at idle, you might want to get in touch with Steve.
