- Mar 1, 2005
I am installing metco adj uppers and fixed lowers. Got everything no problem execpt for 2 questions please help if you know.
Please keep in mind rear end is already OUT. So I can not use the directions like they say, take one side off at time etc....
1. Where to drill hole in the ICM brackets?
Do use the template or is the pinion angle different.
If I do use the template which of the 2 holes is correct 4 T/R's
2. Initial upper setting, does that also fall back to pinion angle. How do you set?
If this does not work I guess will have to reinstall factory stuff and start back over
It would be a lifesaver if someone can tell me any tricks on this.
If anybody has pics of after install would be excellent
