qksilverf1
- Nov 15, 2005
ok ive been doing some research on the internet and what do you know, the internet sucks at giving consistent info. here goes
this site says a 50.50 water ethanol mix is best and the Meth is not good.
i quote
" 4. Methanol, as an additive, is not a practical choice as it is prone to pre-ignition, is not safe to handle and is not readily available."
http://www.rbracing-rsr.com/waterinjection.html
I dont see how the "prone to pre-ignition (knock)" can be true due to its high octane rating and that ALOT of people use it to reduce knock Including those people in the indy 500 who run straight meth for fuel.
Other sites say methanol is the best, one even says straight meth is not corrosive to your fuel system or rubber.....
"Methanol has no effect on rubber, neoprene or OEM carburetor or fuel system parts nor does it get stale like gas does. But it will corrode aluminum as plain water does if it is not drained and allowed to evaporate from the fuel system over an extended length of time."
http://sneakypetespullers.com/technical Articles.htm
Why do so many people talk about how corrosive to the fuel system it is?
Wikipedia gives these octane ratings for the fuels
Methanol 123
Ethanol 129
from (scroll half way down to the table)
http://en.wikipedia.org/wiki/Gasoline
This site says
Methanol 99
Ethanol 100
http://www.leeric.lsu.edu/bgbb/7/ecep/auto/m/m.htm
This site says
Ethanol 113
http://www.gov.mb.ca/est/energy/ethanol/ethanolfaq.html
http://www.srtforums.com/forums/showthread.php?t=107888
FastAttack says
"Alky , is a type of alchohol used primarly to decrease the temperatures of the charged air , although cheaper than methanol , it will vaporize a lot faster than methanol or water thus not having the same level of efficiency in cleaning your motor and preventing detonation."
Doent all fuel vaporize by the time it is ignited anyway??? im pretty sure enough heat is produced during the compression stroke to vaporize all the fuel "gas/meth/eth/water" etc. in the cylinder also if eth has a higher octane rating than meth wouldnt it be better at preventing knock?
Here is an MIT PDF about Direct Ethanol Injection
http://lfee.mit.edu/public/LFEE_2005-001_RP.pdf
Other sites with info if you are interested
http://www.energy.ca.gov/afvs/vehic...s/methanol.html
http://www.agriculture.state.ia.us/e85q&a.html
http://www.palatineoil.com/fuels.html
http://www.ncga.com/ethanol/main/your_car.htm
So can someone who actually knows please clear up my confusion.
please tell me what the differences between ethanol and methanol are (as well as advantages/disadvantages to each) and try to clear up some of the contradictions found in my links.
Again please only post if you actually know what you are talking about and can back it up with an understandable scientific explaination
i quote
Methanol 123
Ethanol 129
This site says
Methanol 99
Ethanol 100
This site says
Ethanol 113
FastAttack says
