20psiofevil
- Feb 10, 2013
Very strong!
SignUp Now!69-300-8 I think. Let me know if you want it drop shipped. Same price as Summit or Jegs. Whatever is cheaperWhat's the part # of that cam?
I didn't change shift points. Looks like around 5100 flash on the logs couple frames of 5050 but 5100 is where it was most of the timeDid you change your shift points?
Where was the converter flash stall?
Stock diameter u joint. The driveshaft is a good strong piece thoughWhat style u-joints do you use for this power and weight? I cant decide on going with strange or Lakewood upgraded 1330 style that will bolt up to my stock ds or upgrade to 1350 u-joints and yokes.
Nothing. It's a stock shortblock with unknown mileage. I'll never add any more safety equipment to this car. Probably use a 3800 for next year if I can find an equivalent cylinder head. Car needs to go to the body shop next. This turbo has the potential to run 9.6x with an engine built around it weighing 3500+lbs.Nice! What’s next for this combo?
It wasn't me then because the slowest pass I had was 10.05 and I came off the accelerator because I didn't have my foot flat on the floor. The 10.05 pass was a 1.533 60'. Should have been 1.38Saw one of your launches that got a 10.1X.....around noonish. That thing leaves real good. Well done
1987 White Turbo T - TE60 w/ Alky
12.1@113
Might have been a 10.051. Remember it left good thoIt wasn't me then because the slowest pass I had was 10.05 and I came off the accelerator because I didn't have my foot flat on the floor. The 10.05 pass was a 1.533 60'. Should have been 1.38
BPE2013@hotmail.com
I actually got the Pass on video..i will work on sending it to you when I edit the whole weekends recordings I got..
