milling intake manifold
SNOWBIRD
I was told that there is a formula to calculate how much metal should be cut off intake manifold so ports will align,when block is decked and and heads are surfaced,,lets say a total of .20 thous..... can anybody help
I just went through this NIGHTMARE, OMG, did this suck and take a long ass time to finally get to seal.
We kept doing 20 thou at a time and it finally took after 40 or 60 thou ( I have tried to block this out of my memory ).
BTW, the intakes are not totally perfect so make sure you get someone who knows there stuff or you might get a really wacked out milling job.
As far as a formula, a good way to judge is how much did the push rod move? Mine moved a bunch due to the head and head gasket being much shorter then before. That gave us a good starting mill job.
I also went through this process. There is a gauge that I think Fedral Mogul makes to get the angles. TA performance sells different thicknesses intake gaskets to get the intake to line up.
Jeff
