Nope, not like hitting a limiter. Here is what it sounds like, I actually caught it when I was doing a burnout at work. And no Rick, unfortanutely I don't have the $$$ to have someone else look at it. :/
That is how frustrating this problem is, I am willing to replace the headgaskets because I have tried nearly everything else. I cannot identify if it is mechanical or electrical. It never did this before I rebuilt the motor. It started to happen around 3-4,000 miles into my new build
Here are some things I have observed.
Bear with me here people, this problem is complete bullshit. It is very hard to identify.
It is more noticable at higher rpms.
When the problem occurs, the car picks up very little mph, but if I stay in it, it will eventually start pulling again.
When the problem occurs, boost rises, sometimes it is barely noticable, other times the boost will climb quite a few pounds, but it gets slower. I had it out on the highway, and I floored it. I have my boost set very low (11 pounds so I dont blow anything up). Boost stayed pretty steady at 11 pounds, then the car stopped picking up mph and my boost started creeping hard. I stayed in it for a good few seconds, and all of the sudden the boost DROPPED back down and the car started pulling again. The car smokes when the boost creeps, and then once the boost drops back down, the smoke goes away. I cannot tell if it is WHITE or BLUE smoke. But it definitely smokes.
Crazy. Pick my brain if that was not descriptive enough. I need mental help after this problem
You can hear it sputter right after the tires started spinning, right at the top of first gear.
