Lil Truck
I spend to much time here....
- Sep 26, 2002
When my fuel pump hose went out for good it was under full boost, it only took 2 heavy knocks (recorded on power logger) to hurt the head gaskets (stock type). It was 2 weeks after I fixed the fuel pump that I noticed water loss at the track. Every now and then under cruise conditions I would feel a light shudder/bump in the engine. Coolant loss was only noticeable after a 1/8 mile pass or longer it would loose about a cup or 2. I took the heads off and found 3&4 cylinders were damaged, just looked like material was scraped away from the around the steel ring.
I think you found the problem, but you need to figure out why it occurred?
