Q: Why can't your bolts be torqued?
A: Any bolt can be torqued. The question is: will using the torque method of tightening a bolt give you good, repeatable results? This is important because at top dead center of the exhaust stroke, the piston wants to continue right up through the cylinder head and the crankshaft wants to pull the piston back down the cylinder walls. At high RPM this load can exceed 18,000 pounds of pull on the cap. It is the job of the bolt(s) to provide enough clamping force to keep the cap from separating from the tower of the rod. The problem is a torque wrench only measures friction not clamp load and every time you tighten the bolts you change the mating surfaces of the threads and where the head of the bolt contacts the rod. This changes the amount of friction that must be overcome to correctly tighten the bolt. What this means is if you tighten the bolts to the same torque level, you will have a different clamp load on the bolts each time. Because of the large potential variations in the actual clamp loads achieved by using torque, we strongly recommend against using torque.
Q: Why use torque and angle?
A: We didn't invent this. It has been used by automobile and diesel manufacturers and in the aerospace industry for many years because it is much more accurate than using torque to tighten bolts. Torque and Angle uses the pitch of the threads as a good, repeatable reference for properly tightening the bolts. For example, if the bolt has a 7/16" 20 threads per inch pitch, then one full (360 degree) turn of the bolt will move the bolt exactly .050" (fifty thousandths of an inch), or 36 degrees of turn will move the bolt exactly .005" (5 thousandths of an inch). We have a specification for Torque and Angle for all of our bolts, no matter their size (5/16", 3/8", 7/16" etc.) and our specs are all derived from the pitch of the specific thread on each size of bolt.
