This is my T-type which is back on the road after 6 years and heading for paint in a few days with 5658's in the front with B-body spindles and GTA rears with 255/50's in front. I put the springs in back in 2002 but pulled the motor at the same time.
Rear springs are 22 year old Eibachs and the car sits about level (which looks a little tail down). After it gets driven for a few hundred miles, we'll adjust the rake as required. Since the car normally has 205/60R15's in front and 275/60's in back, I'm not going to lower it too much in front.
Have you thought about the MOOG 5413's for the rear? I put a set on my Regal and I really like the way it made the car sit! I put a set of of GN swaybars on it and that made a huge difference but after installing the rear springs, I think the car rides perfectly. I think the next budget upgrade to that car is going to be the B-Body spindles since they can be had for pretty much free. Did those spindles seem to help the car? If so, in what way, bumpsteer?
In the rear, I'm using a set of stock springs for a NA v-6.
I thought I would contribute to this thread. Just finished doing 2 cars with the 5658 coil springs. Mine is the only one I took pics off. 5658 front and I believe 5665 F body springs out back. I had the rears on my race car for may years and took them off just recently. Ended up triming .25 coil to get the height I wanted.
If I remember correctly all the fender edge measurements are on or around 26.25. Wheels are 17x8's with 245/45 up front and 255/45 out back.
Looks good jeremy,
Thought maybe I should contribute to this thread also with some of my measurements and wheel & tire sizes for the record. I've been running this set up for 2 days now and putting it through some harsh turns, hills, dips and with the new stock OEM bump stops No Rubbing at all and the ride is nice and smooth!! I Also plan to due the Dual piston calipers up front by SSBC along with the slotted rotors. For the rear plans are to up grade to a F-Body rear disc set up.. Future mods will include a full Air-Ride set up..
Wheel sizes:
FRONT: 18" X 9.5" W/ 4.75 backspacing
REAR: 18" X 10" W/ 4.75 backspacing
Tire sizes:
FRONT: 255 /35 ZR18
REAR: 285 /40 ZR18
My ride height measured the same as everyone else measures, 25.5" in the front and 27" in the rear. The tire sizing is what gives the car a slight Raked look. For now we plan on lowering the car slightly a little bit at a time untill we get it at the desired ride height. Lock to Lock there is No Rub and it handles great. Can't wait to get it to the alignment shop and have the magic done!! This project is just in the beginning stages and I'm just doing it to have fun and throw it around the Auto-X, Well Road course is more what I'm after!! :biggrin:
SW.
