More Dyno results
Otto J
I dynoed and modded a Bone stock T-Type today
It was making 11#s of boost and showed 209HP(Damn cant remember torque)
Then we modded it,Heres the list
K&N Cone filter
40# injectors
Turbo Tweak Alky chip
RJC Powerplate
Test pipe-full stock exhaust
Alky-Control kit running Methanol
Boost set at 21#S
Results were 343HP 562Ftlbs of torque
Gonna play a little more with it as it was getting late.
Definetly think i can get it close to 400 with a little more work
Car runs awesome and on stock tires has out of control tire spin under 30MPH
And thanks ro Eric Marshall and Julio Don, NO KNOCK at all!
Nice numbers. What do you think it would run at the track with good tires?
Jason
Otto,
How many miles on the motor?
Does it have the original timing chain and valve springs?
What correction should we factor into your dyno numbers to get
the flywheel hp?
I am going by 20% drivetrain loss, please let me know if I am off base.
Stock
209RWHP ~ 250FWHP (sounds good)
Ottoed
343RWHP ~ 411FWHP (sounds even better)
It sounds like you are really close to maxing out the stock turbo, congratulations.
The owner of the car must be down with OPP (Otto Pernek Performance) !!!:eek:
Sorry bad 80s rap reference that came up in a conversation last night.
You can use it in your marketing / website if you like!!!!:biggrin:
Are you using a chip?????? :D
Oh my god.........Hell musta froze ova....
Nice work Ottoman!!!
ahhhhh Russ ...now I see where you went yesterday :eek: I tried callin but got Otto's answering machine :confused: :biggrin: Otto it has to be nice to have a toy like that :cool:
That could be his window sticker
Down Wit OPP....
Otto,
the flywheel hp?
Stock
Ottoed
John, It was a 48,000 mile unopened motor.My Dyno actually has the abilty for me to input a correction to get flywheel numbers.
Problem is you need to know what the correction is.
Not too sure on driverain loss percent,Maybe locking up the convertor on the dyno would keep that to a minimum
We are gonna play a little more and bring the boost up a little.With a stock wastegate actuator we couldnt get it higher.I had a hd one home but it was to late to go get it.The timing was left set at Erics settings of 23*22*
BTW Nice Nickname!
:eek: That torque is awesome considering the boost and mods!
One of the nice things about this dyno is it lets you load the car at an RPM you set for a time amount you set,SO when it goes into the pull it is already at full boost
Cant wait to get my car on it
Uh,I plead the fifth:biggrin:
Supposed to be a secret from the big guy!;)
