SignUp Now!I ment 3 or 4 treads showing on the top of the rocker and i have plenty of oil flowing to the rockers ,,,,if i do as cris did and go to .050 preload which i think is to much my rocker to valve geometry would be almost perfect
I assume you have iron heads, we usually use a 8.225 with the comp lifters, I just measured a set of the Morel and they are .175 taller at the pushrod cup so a 8.050 pushrod should be correct. Now you were already .025 under that + the roller rockers sometimes need a shorter pushrod. So it is no suprise that yours seem too long. I agree with Mr Brophy too but I know for a fact that wrong pushrods can make these cars noisy. I have set them up very quiet but usually thay make some noise, they will almost never sound like a stocker.Same set up as i had with the cc roller lifters ,,,,champions heads shorter pushrods had 8.200 went to 8.050
The 885 is a race lifter that is designed for .003 preload (almost none) they are going to make noise. If you preload them they do not work correctly and make more niose IME.I have comps 885's on a 215-220 comp roller and they are noisey to the point of some knock. could this possibly be the slope and profile of certain cams ?
