Moroso underdrive pulley kit
INEEDAGN
Seen Your Member
Used moroso underdrives. Comes with the crank pulley, alternator pulley, intercooler fan adapter, used belt of the correct length and the instructions with belt part numbers.
$50 shipped in the 48. Postal MO preferred but paypal available.
Bob Koch
Bob Koch
will this work w a/c 1st inline
Mine did. the only thing I used was the crank pulley. I had problems with car charging at idle so I pulled pulley alt pulley back off and left the crank pulley on. But that was with a stock alternator. My ac worked fine with this setup also. with an upgraded alternator the pulley would probably be ok
sale pending... FWIW I don't recall any charging issues with my stock alt. If so you CAN use just the crank pulley as mentioned but I believe it takes a different belt part number.
I had fun finding that belt. With my new engine I going with a 200 amp and the pulley is going back on:biggrin: Its a nice setup
Well with the instructions I have :) it lists belt part numbers for both configurations, so he's set either way. Payment rec'd. SOLD! Didn't take long. :)
