Moroso Vacuum pump Meziere water pump accessory drive setup
turbobuick
Staff member
I have a complete accessory drive setup that will fit a Buick V6 Stage 2, 109, on or off center. It is all custom made and obviously does not include power steering.
What's included:
1. Moroso 22840 enhanced 3 vane Vacuum pump
2. Moroso Vacuum pump pulley 2 to choose from V belt or cog.
3. Meziere WP125SHD water pump
4. Buick V6 crank mandrel with spacers and pulleys in various sizes. Mandrel is 6 bolt factory style and will fit stock Buick balancer configuration. I also have a 3 bolt one for an ATI balancer if needed.
5. Custom mounting bracket and hardware.
6. -12 AN lines and fittings for vaccum pump
7. Moroso vacuum pump mounting bracket. Not pictured but you will need it and will be included.
8. Alternator with external adjustable volt regulator and pulley
I want $900 shipped for everything which is less than the cost of the pumps alone! The vacuum pump is $500 new not including the pulleys and mounting bracket etc. The water pump is another $450. This is everything needed to bolt on to a Buick V6. I didn't set this up originally but have a lot of experience with vacuum pumps and will be happy to help get this set up and working right on you rig.
How about the Meziere water pump?
Conrad
