Moser 12 bolt 42-76 Rossler TH400 MSBC Holeshot wheels FAST
re-evaluating
Can't even re-member
Brand new GT42-76 Turbo complete with both flanges and clamps $1450
Moser G body bolt in12 bolt drum to drum with 3.73 gear, 33 splined spool, gun drilled axels, lightened flanges, spherical bushings in upper ears, girdle cover. This rear has the best of everything and has10 passes on it. Will take stock posi rear in as partial trade.
Innovative MSBC boost controller version G, comes with 4 solenoids, manual, 10 oz CO2 bottle, regulator, 2 gauges (bottle pressure and system pressure) billet cage mounting bracket $550
Holeshot hole star wheels 15X11 rears with Phoenix 28.5X10.5 slicks with tubes and screws. Fronts are 15X4 with Moroso drag fronts.. These wheels and tires have 10 passes was $1900 new asking $1400
FAST Sequential box fresh back from FAST with new O2 sensor and adapter harness $1400
Rossler TH-400 with trans brake,10" converter CSR carbon fibre shield, HR mount $2700
Metco spare tire well fuel cell with Red Armstrong twin XP Plus pumps (went 140 MPH with this) $650
Dave 502 727 5960 daveunderpressure at gmail
Dave, Call me about the rear end if you haven't sold it yet. I have the 8.5 from my car available.
That's a good deal on the turbo. Those flanges/clamps are not cheap.
TTT for you Dave.
Dave what A/R turbine housing? 1.15? 1.30? Who built the turbo? T4 flange?
Sorry I didn't get any notification that you had posted.. It is a T4 1.28 housing Precision built still in their box unwrapped plastic..
one2rce PM sent
Rear End Trade
I have a 8.5 with 31 spline Mark William axles, 3.73 gears & new Eaton posi. (less then 2000 miles) if your still interested in a trade let me know.
Chris
Whats the smallest exhaust a/r you can get for that turbo?
This turbo spools fast for the size. The 1.01 housing is not all that much bigger than a 90 something ar.
I am not positive I think I heard 1.01 or something like that. Maybe John or someone will jump in.
Ask and you shall receive.
Here are the options for turbine housings:
1.01
1.15
1.28
1.44
Keep in mind that we have twin GT42 74s on our 396SBC.
We had the 1.01 housings and they were too small with 198ci each.
I would try the 1.28 before changing to something too small.
No problem, the wife always says I am full of something.
Every once and a while I guess it is useful information!;)
My car doesn't spool well with a ,85 houging 71 gtq, I can't see a 1.28 working on a 231 motor?
The full GT stuff is different, not saying it will work for sure but there is a much better chance.
