ShaunKris
#PROJECT84FORIA
- May 13, 2018
Bummer. Try WattsSo no luck with O&S talked to the guy seems like a nice person just won’t do the work in a hotair , anyway anyone know of other shops that will work in these ?
SignUp Now!Bummer. Try WattsSo no luck with O&S talked to the guy seems like a nice person just won’t do the work in a hotair , anyway anyone know of other shops that will work in these ?
Who made the D/p & up pipe?
It will cost about $6000 to build a forged rotating assembly. Forged crank, forged rods, forged pistons, front cover, double roller timing set, deep sump pan.What does a solid bottom end cost on average ? I’m ready to do it but need someone local I’m from Ontario ca need an average cost for bottom end build
I’ll give you a ring today what time is good for u ?I’m working on a bunch of stuff. Give me a call we can talk it’s easier.
951-970-1433
Have you had any issues with. The up pipe being bolted up as one ? I ask because I’m about to weld mine up the same wayHopefully you can bring your hot air build to life. I’m running a Stage 1 turbo from Work turbochargers, ported intake and heads, 3” exhaust from GN1. Electric fans plus oil cooler , with a high flow water pump through a 4 pass radiator. Definitely brought the car to life.View attachment 398916
Hi, do you mean welding it where they join up as a slip fitting? i have not had any issues with mine. Its definitely alot easier to work into position when its in 2 pieces. i think you may have sealing issues when you try and bolt it up to the turbo, i would just use the band that comes with the pipe. Hope this helps.Have you had any issues with. The up pipe being bolted up as one ? I ask because I’m about to weld mine up the same way
Sorry should have Been more clear meant this sectionHi, do you mean welding it where they join up as a slip fitting? i have not had any issues with mine. Its definitely alot easier to work into position when its in 2 pieces. i think you may have sealing issues when you try and bolt it up to the turbo, i would just use the band that comes with the pipe. Hope this helps.
I’m going to have that bolt connection at mid up pipe and the connection at the turbo is that what ur referring too ?Ok, gotcha now. i have not had any issues on the up pipe, other than bending it with some heat and a long bar when i was trying to get everything lined up on initial install. i can't see any issue welding it at the joint, but you are going to lose ease of mating it to the turbo. Just my 2 cents.
A
I'm trying to get on the same page as you. Which pipe are you considering welding, the up pipe or down pipe?I’m going to have that bolt connection at mid up pipe and the connection at the turbo is that what ur referring too ?
Where did you find your up pipe and headers? I found a set on Ebay for cheap and was wondering if they're any good. That set up looks awesome in there.Hopefully you can bring your hot air build to life. I’m running a Stage 1 turbo from Work turbochargers, ported intake and heads, 3” exhaust from GN1. Electric fans plus oil cooler , with a high flow water pump through a 4 pass radiator. Definitely brought the car to life.View attachment 398916
Hi, the up pipe and headers are the ones off Ebay if you can find them. i had a local welding shop do some mods to help with the fitment.Where did you find your up pipe and headers? I found a set on Ebay for cheap and was wondering if they're any good. That set up looks awesome in there.
