Motor making a pounding noise
Beater or no beater its best to fix whats broke so she can live to play another day:D
Nope no leaking fluid anywhere. This may sound dumb but is there any way I bent the flywheel..because it sounds like it's making that clanking noise intermittently as the flywheel is swinging around.
Not likely.
But so anything is possible.
With 4 girls and a cowboy flogging his horse...
I'm only runnin about 15lbs but I mean...my car absolutely loves this weather. Oh and trust me it's away for the winter. It's already being torn apart.
yeah yeah - we know.
The most wonderful time of the year - to blow a head gasket.
I go sideways at 55 mph on the highway if I'm not careful.
Like to the video. Nothing special thats actually my first YouTube video ever lol
Please watch it and let me know what you guys think this noise really is.
Like I said it wasn't this loud before...it actually made me believe it was in the intake before I took this video.
Check the torque converter bolts thats what my buddies jeep sounded like and he had a bolt loose
I'm Laying in bed, I got an exam at 7 tomorrow that I just found out about and I'm hoping the kid that sits next to me shows up ;)
But when I get off work I'll crawl under there...oh man do I hope it's just a loose bolt.
A car lift in my garage sounds amazingly awesome right about now
What does your oil pressure read???
No way in hell is that a TC bolt...
That is NASTY sounding!!!!!! Pull the oil filter, cut it open and look for metal
Bryan
Bryan
Oh shit really? You're scaring me now!! When I took off my valve covers I could see one or two very very verrrrt tiny metal shavings of metal in the oil around my lifters
Bryan
Yeah - I sort of agree too.
It's more clicky / engine sounding.
videos aren't good indications of troubleshooting using sound. The mic doesn't pick it up just right and then end users speakers will change it again.
If it's the torque converter bolts you're a very lucky man. When they are loose, they sound WAAAAAYYYY worse than you would imagine. Checking them for snug won't take more than 1 minute.
From that video, it sounded like you were on fast idle and a rod is getting ready to shoot out the side of the engine.
What doesn't make sense is earlier you said there was no noise in the pan area and it was localized to the drivers side up top.
I guess you can always pull the DS valve cover, hook the plug wires back up and start it again.
Oil filter is easy to remove and cut open...if you saw metal on the topside of the motor, there is more
Bryan
You can't see the lifters from under the valve covers.....
and what kind of shavings? Like dust, or slivers? and will they stick to a magnet?
Damnit I'm a noob..I didn't even check to see if they would stick to a magnet but it looked like slivers to me. And you are right I didn't hear it from the pan but I think I didn't hear it that time because I was on the passenger side of the car and that's where the exhaust is and like I said my exhaust is very very shitty..
Bryan
Yeah that sounds just about right..:/ so if there are shavings what does that indicate :/
since you're not running a torque converter cover, walk outside, grab a 15mm wrench and give whatever TC bolt you see a yank. If it's loose, tighten up the other three and sleep better tonight. If it's not.....
Ok bare with me for 10 min. I'm gonna do that right now.
If it's loose tighten up the other *two*, for a total of three. I made a typo.
