SignUp Now!I would not add any more parts to the mix until you isolate whats causing the problem.
Did you get a reprogrammed chip and injectors checked out OK?
The cam is a hyd roller and is cherry... I just had it out of the motor for inspection and it still looks like new.![]()
I got a similar issue as you do but mine is at 6K. Going to an all day track rental tomorrow loaded up with a ton of extra parts to figure this outI'll let you know if I find it, may be the same thing
The whole theory behind it makes complete sense... adjust valves with preload, and oil pressure (hydraulics) may possibly overcome that preload or the valvesprings, leaving the valves open when the lifter is on the base circle of the cam...
Setting the valves at zero lash, and there is no possibility of the valves hanging open, NONE.
That's my theory and I'm sticking to it. (unless it doesn't fix my problem)![]()
All you have left mechanically is the lifters so you will have the answer soon.
Yeah no kidding... lol
I've replaced just about everything else...
Funny thing is... I've had a helluva lot less trouble with high-mileage bone stock motors.![]()
Its almost always worth it when you get it sorted out though.
If the valves were hanging open, look out. I'd imagine your in for a whole lot more power.
Post some under hood pics of the nos set up. I'd like to do something like that.
How are you venting the fuel cell?
	An overly advanced cam would give the tendency for knock and hurting top end power.
