vacuum 6
- Jan 6, 2006
subscribe
SignUp Now!Overly advanced would cause detonation down low if anything. There woudl be lower bmep as the rpm increased advancing
I had beehive springs on the iron heads with this cam... and 6200 was smooth as silk. It actually wanted to go higher if I let it.
What kind of pressures do the single beehives make ?
(Bison has mine now)
Here is the cam card:
Ill check a few of them next week if you want
The un modded ecm will work for a test. You just should not use it primarily.
Your not running a stupid caspers cam sensor cap, are you?
Have you tried running in limp mode?
Try another set of plugs. This has worked for me at least 5 times over the years when i knew the ones in there were good.
1) have you checked the reluctor wheel inside the cam sensor to make sure it's not broken or loose?
2) have you tried swapping plug wires? I'm not sure how you test them to be good. I had brand new wires (brand not mentioned) that were bad and kept me at 5000 rpm or so. Realized the problem when I got shocked just touching around the wire/coil pack area with the engine running.
I can't see this being a mechanical problem.
Eticket brings up something that I fought with at one time. My ignition system under high load would break up from high tension leakage if the dielectric grease in the spark plug wire boots was inadequate or not there. And,... I have to make sure both ends are greased. Not just one end or the other.
You could have crossfiring occurring too. Make sure there is adequate separation of the high tension leads.
