I'm about out of ideas now.
I've been screwing with this car for 2 weeks now and still have the same problem.
5200-5300 the motor falls on its face and sputters... like a soft-touch rev control hits it.
I've gone over EVERYTHING.
Cam sensor re-adjusted/confirmed dead-on.
Crank sensor replaced - gapped at .025".
Brand new AC Delco coilpack and module.
MSD wires are good.
Autolite AR3935 spark plugs.
Tried multiple chips.
Brand new A1000 fuel pump.
Brand new Magnafuel regulator.
All grounds and ground wires have been checked and doublechecked.
Compression checked - all 6 between 145-155lbs.
I'm running Sunoco 112 leaded race fuel + straight meth
I've tried both alky and race chips, with and without meth injection.
I've had cronic KR problems too... and I wonder if it's related to the valvetrain. I was getting 15 degrees KR just free-revving in the driveway... I went over all the valves and tightened them another 1/4 turn. That helped a little, but not completely.
When I adjusted the valves, I set to zero lash, then another 1/2 turn. After the re-adjustment, they are now at 3/4 turn in from zero.
I'm starting to wonder if this is a mechanical problem now.
Before replacing the entire top-end of my motor, it would rev clean up to 6200 no problem. That was with ported irons, beehive springs, stock rockers and 214/.548 hydraulic roller.
The changes I made were:
TA SI aluminum heads, complete with their springs.
Springs are: 140lbs on the seat and 325lbs @ .584 lift
1.65 T&D roller rockers... (increasing lift from .548 to .584)
Champion aftermarket intake & plenum
I'm not running an RJC plate... (yet)
So that leads me to two possible conclusions...
A) The 1.65 rockers are too much for my cam/lifter combo and are collapsing the lifters at high RPM.
B) The Champion intake & plenum have airflow distribution issues and need the RJC plate between them.
A few things I HAVEN'T tried yet:
1) Replacing the ECM (I only own this one with modded drivers for the 83's)
2) Replacing/inspecting the injectors (they worked fine in the old combo)
3) Tightening the valve lash even more...
Any other suggestions ??? I just don't know WTF to do... and I'm running out of ideas.
Here are two PL files from this morning...
The 2nd one is with the knock sensor unplugged, just for comparison. It made NO difference whatsoever.
