SignUp Now!Frame 1118. Why does the timing jump up 4 degrees? The knock starts in immediately after the jump up in timing.
What parameters are you using to check your afr?
O2 Volts only?
ECM afr looks off. Why?
No W/B afr reading. Why?
Exhaust temp looks low for gasoline?
I have the same beehives on my GN1's and they have been to 6700 at least 3x so far. No bent valves. I shift at 6300 and have not found them to be a problemMy MAF readings do the same thing. Never caused an issue for me. Valve springs may be your issue. I have more spring pressure than you and a smaller "bump stick".
I'm a little skeptical of a plug or wire issue. The car runs fine up to 5000rpm. If it was a weak s-plug or wire, the condition would be more boost related. Not rpm.
RPM issue points more toward a sensor or mechanical problem.
At this point I'd check the valve spring pressures.
One more thing, on the logs you posted, I'm not seeing the wideband signal. You are running a lm-1? Are you able to view the wb data on your pl?
Well... the plugs didn't help.
What is you seat pressure open and closed if you don't mind telling?
Hey art sorry I didnt make it up there tonight i just came in from working on the car.. I got stuck at a house fire till about 5pm and that totally messed up my plansI didnt get done messing with the car till about 10 mins ago
I seriously doubt that you have a valve spring issue. Everyone likes to point at that when rpms are an issue, but that's normally a problem on much bigger cams (longer duration and higher lift) and motors dropping boost.. not, not making rpms.. we're talking solid rollers spinning past 7000k and 30psi.
I'm still thinking it's electrical! ok.. I've run out of 2 cents.
I would tackle the obvious first. Get that timing smoothed out at the transition and see if it helps the knock retard. That jump is no good.
