Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
.......... It looks like timing falls off gradually as boost increases, then all of a sudden it jumps up 3 degrees and there is a blip of KR and the motor falls off. It looks like the timing locks on steady at that point.
If the KR is pulling timing, why doesn't it show up in the PL files ?
Does the PL show programmed timing or actual timing ???![]()
I ans answer this
I did not look at the log, but if the LV8 changes (drops), it will increase timing.
Ok, scrap that, LV8 looks stable.
I did notice that right at 4900 rpm, O2's jump 846. Maybe too rich and flooding the motor?
I know (as you do) a WB will tell the tale, but the NB is not that warm I am sure, so I am guessing this is about a upper 9:1 ratio. Don't know. Furstrating for sure.
In the end, I am just another set of eyes looking at the same stuff.
LAST edit, I promise! :tongue:
Looks like a very similar issue.
http://www.turbobuick.com/forums/general-turbo-buick-tech/167768-car-breaking-up-above-4900-a-2.html
