b4black
- May 24, 2001
I have been considering going with MSD's Boost Timing Master, or BTM, unit. These units retard timing relaitve to the amount of boost pressure. They use an adjustable knob to set the amount of retard per psi of boost. I think this is one of the keys to controlling timing and therefore running more boost (Right Fred?
There are two models available. The first is a combination MSD 6AL and BTM (Called the MSD 6 BTM). Accoriding to the catalog, it will retard timing 1-3°/psi up to a maximum of 15°. There is also a built in rev limiter.
The other is a stand alone BTM unit. It can retard up to 20°. While it is not a MSD 6AL, it does mention it has a "built-in inductive ignition" which increases the spark output.
The difference in list price is significant. The MSD 6 BTM #6462 is $868 and the BTM alone #5462 is $373. (These suggested list prices are probably double what most distibutors charge.)
I think the BTM is the far better buy. It is capable of greater retard and from what I have read, the GM HEI has plenty of spark, so the MSD 6AL isn't necessary.
Anybody running one of these or something like it? Do they work on CCC ignitions? Anybody running a MSD 6AL without the BTM and did it make a difference?
