SignUp Now!BUT will edelbrock intake fit the stage 2 heads?none are really any lesser of two evils, all options to make NA power suck when it comes to the buick v6.
its either big complicated money to squeeze the power from the stocker, or save the big money for an assembled stage 2
I say for what you really want to do.......... stage 2..... or at the very very very least, a Stage 2 top end on your factory block.
what more to say, the block needs heads that can breathe for that kind of power in NA form, and stage 2 is the only way ive ever seen it done..... reliably.
frankenstein liked the cam grind an charlie was the one who pointed it out but you think i should go bigger?
I still say a pair of Series II heads with a custom made intake would work like a charm here. Same basic port configuration as a Stage II head and bigger ports than the stock heads, not to mention a smaller combustion chamber.I say for what you really want to do.......... stage 2..... or at the very very very least, a Stage 2 top end on your factory block.
well I dident weld em so cant take credit there
they really are rare? huh weeell to bad![]()
Sorry about that Aj. Kjetil and I traded on a set. I got the later KB "turbo" valve covers and he got those for his car.LMAO, yea there not easy to find, i wouldnt mind a set myself to add to the collection.
