Phoneguy
Cometic HG stress tester
- Aug 27, 2002
Congrats on the 9 second run !!! I just got mine a couple of months ago. Been a LONG road for me....
Bryan
Bryan
SignUp Now!Hi BryanCongrats on the 9 second run !!! I just got mine a couple of months ago. Been a LONG road for me....
Bryan
Yes that is me ...Hi Bryan
It is a great accomplishment hitting the nines finally, well at least for me it is.
Are you Bryan Lynch?
I just looked at your times in your signature and it matches with what you have told me. I am friends with you on Facebook ( Marco Silvestri). And we have written to each other. Well , I got the car figured out and it was my plugs that were fauled. They were to cold for a street car. Talking with Otto , he told me to run hotter plugs for a street car. So I got the same plugs from NGK but 2 degrees hotter. Went and test out the car the other night and no more hesitation or popping. Should be going back to the track next weekend to see what the GN is going to do.Yes that is me ...
Bryan
Nice that you got it figured out...I just looked at your times in your signature and it matches with what you have told me. I am friends with you on Facebook ( Marco Silvestri). And we have written to each other. Well , I got the car figured out and it was my plugs that were fauled. They were to cold for a street car. Talking with Otto , he told me to run hotter plugs for a street car. So I got the same plugs from NGK but 2 degrees hotter. Went and test out the car the other night and no more hesitation or popping. Should be going back to the track next weekend to see what the GN is going to do.
Good luck !Nice that you got it figured out...
i just put a set of 275 Pros on my car , going to the track tonight and hopefully make a clean pass without the tailpipes hitting the HR bar and the springs. My 9.84 pass had a lot of knock for the first 4 seconds, shooting for a 9.7x tonight.
Bryan
That’s great Bryan. Even though you beat your personal best by a little, it is better then nothing at all. Were you still getting knocks at the beginning of your runs or was that solved?Well it went a little faster ...
9.809 @ 137.47 just touched 29 psi at the top of the track.
Bryan
Still getting knock on the hit for about 1 second. I went to the track hunting a 9.7x and almost got it so I'm happy with it. Still need to do some tweaking on the tune as it is pig rich up top, 9.2 AF ratioThat’s great Bryan. Even though you beat your personal best by a little, it is better then nothing at all. Were you still getting knocks at the beginning of your runs or was that solved?
Me and you would have a blast racing each other. We would be neck to neck. What is your method to launching the car?
Foot brake or trans brake?
Yes , 9.2 is pig rich. If you could lean it out would be great, for sure some HP on the table left there. What ecu do you run?Still getting knock on the hit for about 1 second. I went to the track hunting a 9.7x and almost got it so I'm happy with it. Still need to do some tweaking on the tune as it is pig rich up top, 9.2 AF ratio
Foot brake at 5 psi, 3000 rpms.
Our cars are very close to each other, would be great races
Bryan
Do you have signal or dual injection alky?Yes , 9.2 is pig rich. If you could lean it out would be great, for sure some HP on the table left there. What ecu do you run?
I have had an XFI since 2007 ...dual nozzles, 2 M15's , all inYes , 9.2 is pig rich. If you could lean it out would be great, for sure some HP on the table left there. What ecu do you run?
Who tuned your car?I have had an XFI since 2007 ...dual nozzles, 2 M15's , all in
Nice numbers! Crazy torque! What turbo are you running? And Heads?Patrick Broughton and Cal Hartline.
Cal tweaked the tune on the dyno at Brian lorenz's open house. 640 HP 856 TQ at 27.04 psi
The turbo is a Borg Warner 9174 EFR heads are Champion race ported aluminum's.Nice numbers! Crazy torque! What turbo are you running? And Heads?
Cal tuned my car remotely last year but I couldn’t finish my dyno session with him. Long story short, Cal is amazing but the moron operating the dyno had no f&$king clue what he was doing and fried the hell out of my transmission. We had stop the tuning at 21 to 23 lbs of boost but was no difference because the transmission was finished. Last number was a 592 hp to the wheels . I wish I could have continued so I would know how much HP I would be doing. I will assume something similar to yours. How much does your car weigh?The turbo is a Borg Warner 9174 EFR heads are Champion race ported aluminum's.
Bryan
Cal didn't get to finish turning mine either just wasn't enough time. He spent about 5 minutes on my tune and 1 Dyno run, I think there's a lot more in it.Cal tuned my car remotely last year but I couldn’t finish my dyno session with him. Long story short, Cal is amazing but the moron operating the dyno had no f&$king clue what he was doing and fried the hell out of my transmission. We had stop the tuning at 21 to 23 lbs of boost but was no difference because the transmission was finished. Last number was a 592 hp to the wheels . I wish I could have continued so I would know how much HP I would be doing. I will assume something similar to yours. How much does your car weigh?
