Mr. T-Type
always broken
- Jul 23, 2002
I fixed everything with the engine today. MAF sensor was bad, TPS was bad, and 2 vaccuum leaks. Car runs like a dream now.
Now, I just need to know what the best voltage for the TPS is. ALLDATA said 0.40 +/- .05. Its at 0.42 right now, but I was wondering if moving it up to 0.45 would help in any way. A local GN guru told me it should be between 0.42 and 0.46. Any suggestions?
Also, the car will stall sometimes when I make a left turn and let off the gas. I can prevent it by staying on the gas, but I don't like the fact that if I need to let off for some reason, the car will more than likely stall. Anyone have an idea as to what it might be? I don't know if its left turns only, but I do know that last 2 times it happened, it was to the left.
Last, what do 36# injectors look like (or what is the part number)? I had a master technician looks at them yesterday and he told me that they looked like the stockers and there is no way they are 36# ones, but the person I bought it from swears the are. And I just wanted to check. I don't know what brand they are, but they are all white. I'll get the part number off them later tonight unless someone knows it off-hand.
Thanks in advance for the help
