How would you tell them apart.Ho Chi Minh is Vietnam not china my friend.
SignUp Now!How would you tell them apart.Ho Chi Minh is Vietnam not china my friend.
This bullet point below. Does this mean out of the box or above and beyond the GN1s?The truth will set you free!!
This was a fun project!! It was nice to compare two products side by side. We took some serious weight off the TA's with this process.........and it took more than 5 minutes Brian!!!! I bet we spent an hour or more on each head.
But I'm sure Rick's results will be well worth our effort.
This is the first set of TA's I've looked at and re-worked. So far, I am impressed. I would buy them un-assembled with the valve job done to make the rework faster. I can see even more opportunity to obtain more flow out of the TA heads, but I'd want to verify all changes on a flowbench.
My feedback on the TA's:
- Overall a Very Nice product
- Valve bowls should be pocket ported out of the box (nobody would want to use them as shipped)
- Combustion chamber should be CNC machined out of the box
- Lot of potential for more flow
- Overall cost is more than the GN1's
- A specific set of rocker arms is available that avoid the pushrod interference problems inherent with the GN1's
- Better Availability than the other alternative
It would be a real shame if you were to quit, I mean a crying shame. Hope you re-consider!!View attachment 284349 View attachment 284350 View attachment 284351 View attachment 284352 Here are a few pics of TA heads I did recently. Probably the last set I will do. Trying to quit.
Which head has been faster? We have flowed a bunch of heads, small valve GN1s, first and 3rd gen GN1Rs, ported TAs that weren't that great, and a set of TAs that were killer. All by the same place. The killer TAs flowed the most, but the 3rd gen GN1Rs weren't the highest flowing GN1Rs available. Without having a set of those, I cant speak for them. I know what the high flowing TAs flowed on another bench, and what they flowed when we had them done, and it wasnt close, but atleast a apples to apples comparison, and we know how fast they have been.Looks like some nice work there!
I think the Gn1's will flow better out of the box, but the TA's have more potential when fully ported.
Sent from my XT1254 using Tapatalk
Which head has been faster?.......
I agree. I think it is just a matter of figuring out how to get that power out of them. Look how every class gets faster, especially TSM. Not much has changed in the heads. I went from small valve GN1s that flowed in the 230s to GN1Rs that flowed 257 peak, and flowed more the entire curve. The car made the same power once the backpressure came up. Power was up at lower boost.To get a car in the 7's there is so much more involved than just flow #'s its really hard to say how important that single variable is to the entire combo.
My personal experience FWIW: I still think you can get a stock style head car down the front half of the track faster than a S2 head car which can be an advantage in a Buick due to aerodynamics.
I believe S2 heads are out front because most of them run cam profiles more appropriate for the RPM range that the motors are running in for those speeds and we have more experience making big HP #'s with them.
I believe a TA head that flows 85-90% of what a S2 head does with a smaller valve, less port volume and higher port velocity along with the appropriate cam profile for the RPM range the motor is going to run in, can have an advantage over a S2 head.
Which of the 2 heads has the best et and mph, Champion or Ta. It seems Ta's outflow the Gn1 on the intake and Gn1 outflow Ta's on the exhaust side.
Our experience with Champion and TA alum heads with max ported versions is that their performance is about equal.
When the first 109 block went into the 8's, it was with Champion heads we prepared on a TSM GN, and a stock intake which had been welded to raise the ports to match the increased height of head intake ports. The calculations to accomplish this is well over 900 HP.
The TA heads have excellent flow on the exhaust side and requires little port work, mainly just a clean-up and port match for applications well into the 9's.
Availability of TA heads is outstanding, as I stock many SI and SE heads for various levels of performance.
I flowed a bunch of them and from my experience the TA GN! and even M&A exhaust ports were all very similar when comparing comparable ported heads.The TA heads we tested had better exhaust flow than the Champions, but that can be a bad thing when back pressure is high.
