The old filter adapter shows some uneven scoring from the gears, and upon inspection it looks like the pump shaft may be ever-so-slightly bent. If the pump shaft is bent at all, is it necessary to replace cam sensor also?
Wanting to be sure I do this correctly, so if you could, please comment on the following:
Thanks!
~Dave
- I've read the pump gear-to-adapter end clearance should be around 0.0015"?
- I have an SBC priming tool with collar. The collar is non-adjustable; is the position of the collar the same for the Buick?
- I plan to use mechanical gauge on feed block to check pressure while priming;
- Rotate the crank a few times while priming, until both rocker shafts see oil.
Thanks!
~Dave
