Need a Trannsmission rebuild
What is the actual problem with the trans? Is it overheating? No 200-4R trans can handle excessive heat. Do you have the radiator hooked up plus an aux cooler? Contact me if you like, we can discuss fixing what you have, I am located on long island.
Hi Dave,
It has an aux cooler but is not running through the radiator.
I'm thinking about bring it to you.
Tired of fooling with it.
What is your turn around time this time of year?
Thanks,
Bill
Hi Dave,
Thanks,
Bill
If there is a wait, it is well worth it.
Its very important that the detent cable is properly set after install.
Hi Dave,
Thanks,
Bill
Hey Bill, what is the rating on the aux cooler. I am thinking the trans overheated and failed. Removing the trans from the radiator is a bad idea. The heat will show itself when opened if that is the cause.
I can turn a trans around in 2 weeks or less usually. I have many motor builds I am working on right now and it slows down the transmission work sometimes. Let me know your concerns with time?
