need advice
Need more info. Is this for an upgrade from? Need to list mods in your signature and your intended mods requiring a new waste-gate.
Sorry just seen a lot of guys adding wastegates and blow off valves to their engines and heard it saves your turbo when you instantly let off during high boost just thinking I might upgrade to one or the other , my car has t44 turbo 43lb injectors running 20 lbs of boost 3000 stall 3" terry houston downpipe 77mm throttle body stretch intercooler . So nothing dramatic just thinking of upgrading .
Blow-off valves are not necessary on our cars and if you are not having a problem w/your present w/g, there's no need to change it. However, if you are running 20#s of boost on 93, you should invest in a scan tool like scan master and alchy.
Having no issues just asking a simple question ,to be easier on my turbo when I let off of accelerator for the pressure that is still there to escape is a blow off valve or waste gate an option.
The blow-off valve is what you are referring to. the w/g is what is used to control the boost.
