Need Help CHoosing Cam
LilSpann601
WHats up I have a 3.8 na im rebuilding with a carb turbo...ive already had my heads and everything did so i didnt want to send the heads back to the shop just because of the cam...I was wanting to know will this cam work without any modifications ??
Buick V6 Even Fire Cam .424"/.448"
"181, 196, 231, 252, 1977-1987 (Even Fire W/Integral Dist. Drive Gear)
Performance Hyd Camshaft
Duration @ 0.050 Lift: Int. 194° /Exh. 204°
Advertised Duration: Int. 260° /Exh. 270°
Gross Valve Lift: .424"/.448"
Deg. Lobe Center: 114 LC
It will work with no mods. :)
