Need help identifying calipers
turbognx75
Not sure they look like vette brakes but just not sure!!! Any help would be great and I'm sure they would not work on our buicks and I have 4 pistons and I need two more I'm thinking dealership for those but first need to find out what they are,, thanks tony
I could be wrong but they look to me like maybe 4th gen F body or S10 brakes. Are there any casting numbers or part numbers on the calipers or brackets? If there is I can probably find out what they are originally from. They look nice whatever they are :)
I found a date of 2/18/99 so f body or corvette I'm guessing they used the same brakes between the two and I take it that they won't work on our buicks...
As mentioned look like PBR calipers from a F-Body, Corvette, etc. they are what Baer brakes also sold under there "Sport" moniker, i believe, contact Rick E. on the board, as he is our local Baer rep and Buick owner, he should be able to tell you what brackets are needed and how to trim your spindle.
they'll work- you just gotta modify your spindles and buy/make mounting brackets.. it's not rocket surgery..
