Ok, so this problem has occured just recently. My blms have been acting really funky. No matter what I do (adjusted FP, adjusted translator, changed maf, checked grounds, checked vacuum lines, changed plugs, troubleshooted injectors/plugs) and i can not get it to budge. cruising, my blms are at 115-116 (they used to be almost always at 128, ranging from 125-129). When i let off the gas and let it drift, the blms will go to 124-128 until i come to a stop and they drop again. when i first start the car, the blms will be at 128 and then slowly drop to the high to mid teens in the BLM range. very confusing. at WOT, they go to 128. the oil has a slight hint of gas, and its starting to tick on the passenger side when cold and that is NOT good. my mods are .020 over forged pistons, 160 stat, maf translator with 3" maf, walbro 340 w/ hotwire, 60lb injectors, 204/214 cam, running low boost. PLEASE help out guys, i am getting worried about my motor here. i know that its almost in range, but its not, and the motor has not acted like this before.
