need help wiring fast to crane box &msd distubitor
blownmarkvii
cant get rpm signal ,or spark :confused:
well here it goes :fast bank to bank sys ,crane ingition box high-6r
msd 8582 distubitor inductive pickup ,no crank or cam sensor
heed help on interfacing these wires.
mustang 87 ,306 engine s -trim ,83#
ok these arewires i have:
fast
1.points
2.crank sensor plug red + mag ,black mag-,ground to head
crane box
1 white points or trigger
2 orange goes to coil +
3 black goes to coil-
4 red switched12 volts
5 red to battery
6 magnetic trigger mag+ violet,mag-green
7.black to ground
8.tach wire green
should be same on msd 6al box ?
msd distubitor
1.black orange +
2.black voilet -
can some one help before i have to :headshot: my self.:confused:
Connect the points wire from the FAST to the points input wire on the Crane box.
Connect the two wires from the distributor to the "crank" wires in the FAST harness. Blakc/purple to the red wire, and black/orange to the black wire. Do not connect the distributor to the ignition box.
Drop the weapon... now step away... :D
If the MSD was not involved and I used the stock TFI dist, would I still use the points output on the FAST harness? I was told to take the points off the dist. This is on a Bank-to-bank.
