Need NOS installation Manual
bigz
Senior Member
Does anybody have the installation manual for NOS kit number 5301 laying around that they aren't using? I could mail it back after I get my kit installed. I bought a used kit and it doesn't have all of the instructions. I really need a good wiring diagram to try and get this thing hooked up. If anybody can help me out that would be appreciated.
Mike
bigz@greeleynet.com
wiring
Each solenoid has 2 wires. One is positive and one is negative. Take one wire from each sol and go to ground. Take other two and run to a momentary switch,then to on/off switch,then to fuse box. If you also want full throttle switch you can place it on the ground side then it will only work at WOT.:D
Call NOS and tell them what you have and they will fax it to you. That's what I had to do.
Burnout
