Or weak ignition. The issue occurs only at full throttle. I brake boost to 12 psi and go part throttle to 18psi pull all the way to 5800rpm the car pulls strong but at any point I put the pedal all the way down the car will start to shutter and miss almost if there is weak spark. The wideband shows the af does lean out to mid to high 12's when the issue occurs.
At first I thought maybe it was trans related so I had my trans rebuilt over the winter and had my converter freshened with new carbon cluth. Have replaced plugs, wires, and coils. The methanol is unhooked and it has a lt1 maf that is also new. Loaded an old tune that run great on the car and even swaped a stock turbo on the car.
Seems to me it has to be something in the valvetrain and possiblly valve float. The springs come in a hyd roller kit and the entire valvetrain is less than 5yrs old. I guess I could check spring rates but it would be alomst just as easy to just replace the springs.
Just wanted to get some opinions on if this sounds like valve float the way the car will pull at part throttle all the way to redline with mild boost. If not which direction should I take from here?
