Tim Cucci
- May 24, 2001
I have stock ported and polished heads with Ferra SS valves. Roller cam setup with beehive springs. I just took the engine apart for bearing knock issues. The engine was smoking a little and during the tear down I noticed everything from the intake runners down to the pistons and plugs had oil moisture and plugs were wet. After research on this board I've come to the conclusion that the Exhaust Valves having no seals in place may have caused a lot of the smoke and oil in the runners and combustion chambers. The heads are really in good shape and I don't feel as if they need any valve work.
My question is do I need to have the exhaust guides cut down for seals and can this be done by drill press and end mill and or by hand. I would like to do it myself. How accurate does this work really need to be?
