Just installed my 1st scanmaster in an 86 GN. HAve been reading about advantages, but not on the best process to collect the data.
Some report their data on an idling car, others that are under power.
Do I collect data:
Idling
Under WOT (and if so, for any particular distance, speed, or rpm)
Cruising
Also just bought a turbo tweak hot wire kit. Should I wait till I've installed it b/4 going WOT? Car mods (came with car) are:
42# inj
3" down
2.5" duals no cat
larger Garrett turbo (rough measurement of 55mm turbine)
cold air kit
everything else stock
Have replaced:
fuel filter (felt that!)
IAC
EGR
vacuum lines
plugs look clean and definitely a little wetter since new fuel filter
Carl
Do I collect data:
Idling
Cruising
42# inj
3" down
2.5" duals no cat
cold air kit
Have replaced:
IAC
EGR
vacuum lines
Carl
