Needing complete pump
N2BUICK
TurboBuick.Com Supporter!
Old problem posted last Oct. fluid coming out of puke tube cold at idle.
Bruce said maybe cross leak in pump.
Is his $400.00 pump the answer for a real good pump? I saw CK had said
a reman for alot less. What the good better best on this item ?
I don't usually skimp on parts for my turbo cars, but dont want to overkill.
Car has 10 second type parts with a 14 second driver :smile:
I got BRAND NEW pumps
If you need one they are in stock and ready to go. All I need to know is what boost valves you desire and if it is a lock up or non lock up.
I can set you up cheaper than that also.
Let me know if i can be of assistance.
Bruce
We4
Performance Transmission Services
916-739-0510 9-5 m-f
The pump you see on our website is more than adequate for a 10 second application.The parts installed are all proven to be the right combination and will perform.If you want all of those featues in a Brand New GM pump we can update a new one to our specs but it isnt necessary.Abrand new unmodified pump is $165.00 .This may work for you as you can switch over your boost valves and stator tube and your ready to go.
Bruce and Chris, thanks for the replys.
Feel torn on who to buy from. The trans has parts from both of your shops.
I will get with my transmission guy and we will order a pump.
Thanks a lot for both of you for what you add to this board.
Another question
The convertor is a five disc lock up. Whats the pros and cons of using or not using a "sys" ?? tube?
I agree with Chris
I don't know either. Not a big fan of it. Turbojimmy might have some info. I do not like them tho.
Just our opinions..
Bruce
We4
